Wiring d when leakage protector in TN system supplies three-phase balanced load
Source: InternetPublisher:三月小雨 Keywords: Wiring leakage protector BSP Updated: 2020/08/22
TN system, that is, the neutral point on the power side is directly grounded.
In the figure, the TN-C system is a three-phase four-wire system in which the working neutral line N and the protective neutral line PE are combined into a PEN line; the TN-S system neutral line N cannot be connected to the neutral of
other equipment or lines without leakage protectors. Line N is shared and is not allowed to be connected to the protective neutral line
PE, equipment metal shells, wire steel pipes and other metal parts connected to the earth . That is to say,
a system with three phase lines, a general neutral line N and a protective neutral line PE (PE is led separately from the neutral point of the transformer) through the leakage system
is also called a five-wire system.
- The basic principles of power supply design. What are the key components of a power supply?
- Build a simple buck-boost regulator and test it on a breadboard
- Benefits of Wide Bandgap Technology for Power Converters
- In-depth analysis of DC-AC converter inverter
- Energy-saving motorcycle rectifier regulator
- Use pulse width modulation to get a precise output voltage
- Detailed explanation of 5v charger circuit diagram
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- 3~15V 10A adjustable voltage regulated power supply
- Electronic anti-asthma circuit
- High-efficiency speaker circuit for rural stage
- Straw returning to field crusher circuit
- Agricultural spraying and insecticide control circuit
- Farmland irrigation automatic control circuit a
- Domestic KD8041 integrated phase locked loop
- Mixer built with analog multipliers
- Amplitude modulation circuit composed of MC1496
- Broadband high frequency power amplifier circuit
- Digital stopwatch display circuit
