A simple memory reader/writer
Source: InternetPublisher:3228 Keywords: Memory Updated: 2024/10/12
According to the attached figure, find two 4.7kΩ resistors, an 8-pin IC socket, and a female serial port. The serial port in Figure 1 is a male one, which is the serial port on the computer motherboard. When we solder, it is a female one, so we must match the pins one by one before we start.
After soldering is complete, connect the power supply as shown in Figure 1. I used the small battery in the MP3 player.
Install the software on the computer, plug the serial port reader into the computer COM port, and then set it up. Open the PonyProng2000 software, click "Settings - Interface Settings", in the pop-up window, select Serial/S1prongAPI/COM1 for I/O port settings, and click "Test". If there is no problem with the hardware, a test OK will appear, and finally click "Confirm". Complete the test settings.
- Share an electronic touch organ circuit
- How to create a digital watch using YAKINDU Statechart Tools
- Design of a drone wildlife counting system using FOMO object detection algorithm
- DIY an indoor and outdoor webcam
- Share a fire sensor solution using MLX90640
- Simple and easy-to-make electronic mosquito repellent
- Production of wake-up device
- Making an Off-Grid Solar PV System
- A detection circuit with keen hearing
- Detailed explanation of car battery charging circuit diagram
- Memory system reset circuit (TLC7XX)
- frame memory circuit
- Fireproof and anti-theft telephone intelligent alarm circuit-voice circuit
- Class output statistics circuit
- CPU and decoding chip memory, SD memory card socket interface circuit
- CPU input and output and memory control circuit
- Memory protection power circuit during power outage
- Fast memory programming power supply circuit diagram
- Battery powered +12V fast memory programming power supply circuit diagram
- memory protection circuit
