Wiring a when the leakage protector in the TN system supplies a three-phase balanced load
Source: InternetPublisher:宋元浩 Keywords: Wiring leakage protector BSP Updated: 2021/01/15
The leakage protector in the TN system is used for wiring
the TN system when the three-phase balanced load is used, that is, the neutral point on the power supply side is directly grounded.
In the figure, the TN-C system is a three-phase four-wire system in which the working neutral line N and the protective neutral line PE are combined into a PEN line; the TN-S system
neutral line N cannot be connected to the neutral of other equipment or lines without leakage protectors. Line N is shared and is not allowed to be connected to the protective neutral line
PE, equipment metal shells, wire steel pipes and other metal parts connected to the earth . That is to say,
a system with three phase lines, a general neutral line N and a protective neutral line PE (PE is led separately from the neutral point of the transformer) through the leakage system
is also called a five-wire system.
- How about the boost converter TPS61299?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Build a simple buck-boost regulator and test it on a breadboard
- Fabrication of multi-cell lithium battery charging circuit
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Single-power supply circuit for ISO122P/ISO124
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Low cost and high performance LED constant current power supply
- Converting a lithium battery charging board into a constant voltage and current charger
- MIC4680 constant current charger
- Electronic anti-asthma circuit
- High-efficiency speaker circuit for rural stage
- Straw returning to field crusher circuit
- Agricultural spraying and insecticide control circuit
- Farmland irrigation automatic control circuit a
- Domestic KD8041 integrated phase locked loop
- Mixer built with analog multipliers
- Amplitude modulation circuit composed of MC1496
- Broadband high frequency power amplifier circuit
- Digital stopwatch display circuit
