Wiring c when the leakage protector in the TT system is used for single-phase load
Source: InternetPublisher:aerobotics Keywords: Wiring leakage protector BSP grounding Updated: 2021/03/24
The wiring of the leakage current protector (RCD) must be correct, otherwise it will cause refusal or malfunction. The basic requirements are as follows.
① All live conductors must pass through the zero sequence current transformer, but the protective neutral line PE is not allowed to pass through.
② The neutral wire N passing through the leakage protector must be insulated from the ground. In a TN or TT system, the neutral wire N of the neutral current protector passing through the leakage protector
must be insulated from the ground to ensure that the current flowing through the neutral wire N will not be diverted to other lines.
③In the TN-C system, the protective neutral line PE should be connected to the PEN line on the power side of the leakage protector, and
the neutral line N behind the leakage protector must be insulated from the ground.
④ In the TN-C system, after installing the leakage protector, the re- grounding must be located on the power supply side and not behind the leakage
protector.
(1) Wiring when the leakage protector in the TT system is used for three-phase balanced loads (Figure 20-7)
In the TT system, the neutral point on the power side is directly grounded, and the metal shell of the electrical equipment on the power side adopts an independent protective grounding
system.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Transformerless AC-DC constant current LED driver circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Switching power supply circuit composition and function introduction of each part
- CNC regulated power supply production
- 0.7~24V continuously adjustable current limiting power supply
- USB power socket using the car battery
- Homemade home inverter circuit diagram
- electromagnetic field sensor
- Agricultural temperature control circuit
- Egg heating control circuit
- Diode Balanced Mixer Circuit
- Proportional frequency discriminator circuit
- Diode square rate detection circuit
- Differential Amplifier Circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
