AAT circuit for sectional bus backup power a
Source: InternetPublisher:萌面大虾 Keywords: Backup power supply BSP circuit breaker Updated: 2020/11/23
For wiring with two independent power supplies and single busbar segments as mutual backups, the backup power automatic input device (AAT)
should be installed on the segmented busbar circuit breaker , and its circuit is shown in Figure 14-145. This circuit uses a DC operating power supply, and the starting method
adopts a time-limited low-voltage start.
In the figure, the control switch SAi is used to operate the circuit breaker . The selector switch SAz is used to switch the AAT device, and
the contacts in the dotted box represent those from the control loop.
When the load current is low, adjust the potentiometer RP to make the relay KA reliably close.
- 220V Remote Load Monitor
- Fabrication of multi-cell lithium battery charging circuit
- Driving circuit of switching power supply field effect tube
- Single-power supply circuit for ISO122P/ISO124
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- CNC regulated power supply production
- Electric bicycle battery charger circuit
- MIC4680 constant current charger
- Detailed explanation of mobile phone charger circuit diagram
- Motor forward and reverse control wiring diagram (2)
- High-efficiency speaker circuit for rural stage
- Chicken supplementary light to increase egg production rate circuit
- Agricultural small tractor lighting circuit
- Amplitude modulation circuit composed of MC1496
- ring amplitude modulation circuit
- Wien bridge oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order band-pass filter circuit
- Guest arrival signal recognition circuit
