Thyristor overcurrent protection circuit one b
Source: InternetPublisher:三月小雨 Keywords: protection circuit thyristor overcurrent protection power supply Updated: 2020/06/06
When overloaded, detect resistor R. [Figure 14-97 (a)] or RP [Figure (b)],
the voltage drop increases, the thyristor is turned on, causing a large current to flow directly through the protection circuit composed of Ri and V , causing the power fuse FU
to blow out, thus achieving Quickly protect the power supply . Figure (b) passes through a small thyristor U. Trigger the large thyristor again .
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Op amp power supply decoupling bypass measures
- LED rechargeable flashlight circuit diagram
- LNK304 non-isolated LED light string driver circuit
- Boost drive circuit composed of RT8450
- USB power socket using the car battery
- UC3842 Electric Vehicle Charger
- Converting a lithium battery charging board into a constant voltage and current charger
- Adjustable voltage regulated power supply circuit
- Circuit diagram explanation: simple switching power supply circuit diagram
- Overview of 3.7v lithium battery protection board
- Overload protection circuit
- Three-phase motor phase failure transistor protection circuit
- Switching regulated power supply circuit
- Stabilized power supply overcurrent protection circuit 3b
- Thyristor overcurrent protection circuit 2
- Thyristor overcurrent protection circuit one b
- Mains undervoltage and overvoltage protection circuit 4
- Overcurrent protection circuit for generator low voltage starting a
- Asynchronous generator capacitor overvoltage protection circuit
