One of the AC regulated power supply circuits controlled by thyristor
Source: InternetPublisher:难得正经 Keywords: AC regulated power supply thyristor regulated power supply circuit Updated: 2020/08/03
The thyristor - controlled AC regulated power supply has the advantages of simple structure, stepless automatic voltage regulation, wide voltage regulation range, high stability,
small no-load loss, and small power transformer power. The disadvantage is that the output voltage is not a sine wave voltage and has many harmonic components.
The circuit is shown in the figure. When the power supply voltage changes in the range of 190 to 250V, the output voltage of this voltage regulator can be maintained
at about 220V.
Debugging requirements: Connect the load Rh, when the input voltage U- is 220V (can be adjusted with the help of a voltage regulator), adjust
the potentiometer RPz to make the voltage at points A and B UAB - 3.5V, then adjust RPl to make the load The voltage on the load is 220V, then
increase the voltage of Ul to 250V to see if the voltage on the load is 220V. If it is too high or too low, just adjust the RPi appropriately
- Fabrication of multi-cell lithium battery charging circuit
- Driving circuit of switching power supply field effect tube
- Driving circuit that controls LED brightness using PWM signal
- Simple and practical LED lamp driving circuit
- Low cost and high performance LED constant current power supply
- Current/voltage conversion circuit using current converter
- Boost drive circuit composed of RT8450
- A novel and practical DC low voltage stabilized power supply
- Power supply circuit that can reduce LM317 ripple
- Design of electric vehicle charger
- Light control light lighting circuit
- Plastic sealing machine circuit composed of unidirectional thyristor
- Thyristor dimming light circuit
- Thyristor silicon stack protection circuit a
- Taifu DK2-25 rice cooker temperature detection control circuit
- Thyristor on-type delay circuit 4
- Thyristor switch-on delay circuit 3
- Thyristor discharge machine circuit
- Thyristor type AC arc welding machine no-load automatic stop circuit 2
- One of the AC regulated power supply circuits controlled by thyristor
