79-A type automatic AC regulated power supply circuit
Source: InternetPublisher:他们逼我做卧底 Keywords: AC regulated power supply regulated power supply circuit BSP output voltage Updated: 2020/03/13
It uses servo motor and transistor control.
When the power supply voltage changes in the range of 160-260V, the output voltage can be maintained at 220V±3V. When
RP is adjusted so that the output voltage is 220V, the potential difference between A and B is zero. At this time, the bridge circuit is in a balanced state,
the transistors VTi and Vtz are cut off, and the motor M does not move. When the voltage rises, VTz turns on and M reverses. It drives
the sliding arm of the voltage regulator to move in the direction of voltage reduction; when the voltage decreases, VTL is turned on. M forward rotation, the voltage regulation process is opposite to the above.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- In-depth analysis of DC-AC converter inverter
- 220V Remote Load Monitor
- Introduction and principle analysis of switching regulated power supply
- Op amp power supply decoupling bypass measures
- Driving circuit that controls LED brightness using PWM signal
- Switching power supply circuit composition and function introduction of each part
- A small and easy-to-make fast charger
- Adjustable voltage power socket
- The production of adjustable voltage-stabilized power supply composed of LM317
- electromagnetic field sensor
- Analysis of rectifier circuit types and principles
- Fish pond oxygenation reminder circuit
- Rice mill circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Motorcycle flash light circuit
- Various signal generator circuits
- Home appliance repair signal generator circuit
