One of the bipolar regulated power supply circuits using SW1468 voltage regulator block
Source: InternetPublisher:狂妄火龙果 Keywords: Stabilized power supply circuit output voltage current limiting resistor Updated: 2021/12/27
Its output voltage is ±15V and current is 50mA. In the figure, R. l and R. 2 is the current limiting resistor ,
its value can be according to R. 1. Calculation of 0.6V/centre, Ifz is the load current (A).
- Analysis of the working principle of switching regulator
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Visible laser digital control modulation driver
- A novel and practical DC low voltage stabilized power supply
- Adjustable voltage power socket
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- The production of adjustable voltage-stabilized power supply composed of LM317
- Homemade Electric Bike Fast Charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- STR5412 power circuit
- Power circuit of LBO-522 dual trace oscilloscope
- Output 12V-10A power supply circuit
- Household emergency power circuit 02
- ±15V active servo power circuit
- Common power circuits and applications 06
- 25Hz ring current power supply circuit
- Small power UPS power circuit and production
- High quality power supply circuit schematic diagram
- CASPER TM-5158 VGA color display power supply circuit
