One of the switching regulated power supply circuits
Source: InternetPublisher:同住地球村 Keywords: Stabilized power supply circuit switching power supply BSP Updated: 2021/07/19
Switching-type regulated power supply has high efficiency, light weight and low heat generation. It is often used in color TVs, square wave devices, lasers,
electronic computers and numerical control devices.
Its general working principle is as follows: directly rectify the AC voltage of the power grid to obtain pulsating DC, and then
convert it into a high-frequency pulse width alternating voltage of about 20kHz through a pulse width converter (multivibrator), and then perform rectification and filtering to obtain a stable winning current. . The voltage stabilization
process is achieved by utilizing the energy storage function of the circuit.
As shown in the circuit diagram, it can output voltage 20V and current 5A. When the input voltage of this power supply is 35V (1+
10%), the output voltage is continuously adjustable in the range of 7 to 26V, the maximum current is 5A, the internal resistance is 0.1Q, the ripple voltage peak value
is ≤10mA, and the overload protection current is 6A.
- Schematic diagram of car cigarette lighter to USB power port
- Basic connection circuit of signal and power supply composed of ISOll3
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Use pulse width modulation to get a precise output voltage
- Current/voltage conversion circuit using current converter
- Dual forward converter schematic diagram
- Dynamic power supply for power amplifier controlled by thyristor
- CNC regulated power supply production
- 0.7~24V continuously adjustable current limiting power supply
- LM317T voltage regulation adjustable circuit diagram explanation
- Inpatient pager circuit
- Soil water shortage prompt circuit
- DC ammeter
- Frequency modulator composed of NE566
- Diode square rate detection circuit
- ring amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- OTL low frequency power amplifier circuit
- High and low frequency signal generator circuit
- Sawtooth wave generator circuit (2)
