PQS1 series magnetic control disk translation control circuit
Source: InternetPublisher:萌面大虾 Keywords: control circuit BSP controller power outage Updated: 2020/01/05
It is a control circuit composed of a master controller and a PQS1 series magnetic control panel , used to control the lifting control of the lifting mechanism of the bridge crane
. The handle of the
master controller SA has 7 positions: in addition to the zero position, there are 3 lifting gears, which can obtain three different lifting
speeds ; there are 3 descending gears, the second gear is single-phase braking descent, and the second gear is single-phase braking. The third gear is forced descent, and if it is a heavy object, it will transition to electric braking
descent; the first gear can only perform reverse braking descent when shifting back from the second and third gears to the first gear, otherwise it will not work. When parking at zero position,
brake YA acts first, and the motor delays o. The power will be cut off after 65 seconds to prevent the hook from slipping when the power is cut off and stopped when carrying heavy objects.
The pull-in delay of the reversing relay KTi is 0.11N0.16 s, and the disconnection delay is 0.15~0.2s. The purpose is to extend
the switching time of the main contact and avoid causing phase-to-phase short circuit.
- Detailed explanation of the working principle of the parking light circuit
- Method for converting a spark ignition system to an enhanced sequential spark ignition system for a 6-cylinder engine
- Interpretation of CAN bus driving recorder system circuit
- One control two constant pressure water supply frequency conversion speed control circuit b
- Secret code lock circuit
- Infrared blind cane circuit diagram
- Electronically controlled fuel injector test circuit
- Small improved circuit of hanging electronic watch
- "Happy New Year" ring game console circuit
- Simple temperature control circuit diagram
- Pulse therapy circuit
- Crop anti-frost circuit
- Rural vegetable greenhouse lighting circuit
- Agricultural small tractor lighting circuit
- Straw returning to field crusher circuit
- Particle clogging alarm circuit of wheat seeder
- Proportional frequency discriminator circuit
- Varactor Diode Frequency Modulator
- common emitter amplifier circuit
- Sine wave signal generator circuit
