High voltage power frequency warning grid
Source: InternetPublisher:难得正经 Keywords: Power grid high voltage power frequency BSP Updated: 2020/11/10
Its output voltage is 3kV at industrial frequency (50Hz). The power grid can be used for explosives, weapons depots
, etc.
When minor faults such as porcelain bottle flashover discharge occur in the high-voltage power grid, the primary current of the step-up transformer T2 will increase.
The current signal is detected by the current transformer TAz, and a voltage signal is generated on its parallel resistor Ri. After rectification by the rectifier, Take out the voltage signal from
the voltage divider R2 and RP to turn on the thyristor V (the setting of RP can be adjusted), and the buzzer HA will sound an alarm
. SB is the alarm release button.
If a metallic short circuit occurs in the high-voltage power grid, the circuit breaker QF2 will trip while the thyristor V is turned on, and
the red indicator light H2 connected in parallel with it will light up. The power grid is also equipped with a neon bubble indicator to indicate whether the high voltage is normal. When a ground
fault occurs, the neon bulb near the ground point will go out, making it easier to find the fault.
Step-up transformer T2 uses JDJ-10/0. lkV, 640V. A voltage transformer.
- Delayed gradual lighting with protection function
- Six LED stereo VU display circuit built with IC LM3915
- Blinking LED circuit diagram based on LDR and resistor
- A light fence circuit diagram with LDR
- LED Flasher circuit using 2 transistors for LED switching
- Use NE555 to make a lighting and sound changing circuit
- Infrared detection alarm
- "OR" logic element configuration circuit
- Mains undervoltage and overvoltage protection circuit 2
- Application circuit of CAT3606
- soil content measurement circuit
- Soil water shortage prompt circuit
- DC ammeter
- Diode balanced amplitude modulation circuit
- Audio function generator composed of ICL8038
- Capacitive feedback oscillator circuit
- OTL low frequency power amplifier circuit
- Motorcycle flash light circuit
- Sawtooth wave generator circuit (1)
- Sine wave signal generator circuit
