Inductive anti-theft alarm circuit using field effect tube
Source: InternetPublisher:石榴姐 Keywords: Field effect transistor induction type anti-theft alarm circuit BSP Updated: 2020/01/13
Inductive anti-theft alarms use human body induction to alarm when the human body is a certain distance away from the induction piece. The circuit of an inductive anti-theft alarm
using a field effect tube is shown in Figure 13-159.
The monostable circuit is composed of 555 time base integrated circuit A and so on .
Adjust potentiometer RP. The sensitivity of the device can be changed. The sensitivity should be as high as possible, but not too high to avoid
false alarms.
The alarm delay time is t-1. lR2 Cz, so the values of Rz and C2 can be adjusted to change it. According to the component parameters shown in the figure,
the alarm delay time is about 40s.
- Example of LED AC drive circuit
- IR2153 emergency fluorescent lamp circuit diagram
- IRS2530D electronic ballast circuit diagram
- A light fence circuit diagram with LDR
- LED Flasher circuit using 2 transistors for LED switching
- Use NE555 to make a lighting and sound changing circuit
- Infrared remote control device circuit
- Telephone theft automatic notification device circuit diagram
- Electronic rapid starter for fluorescent lamps
- SH-803R holiday lights ASIC
- Ultrasonic blind pathfinder circuit
- soil content measurement circuit
- Fish farming thermostatic control circuit
- AC voltmeter
- Wien bridge oscillator circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Fault signal trip circuit
- Home appliance repair signal generator circuit
- Sawtooth wave generator circuit (1)
