High voltage isolation switch operation display circuit
Source: InternetPublisher:3228 Keywords: Display circuit high voltage isolation switch BSP high voltage circuit breaker Updated: 2020/03/09
As we all know, the high-voltage isolation switch is not allowed to be switched on with load, otherwise arc light will be generated, causing a short
circuit accident between high-voltage busbars and endangering equipment and personal safety. Therefore, high-voltage switchgear adopts mechanical or electrical interlocking devices. Only when
the high-voltage circuit breaker is opened, the isolating switch can be disconnected; when the circuit breaker is in the closed position, the isolating switch must not be closed. The order of operations
cannot be reversed. In order to further avoid misoperation accidents, you can also make your own high-voltage isolation switch operation display.
The principle circuit is shown in Figure 13-114.
In the picture, QF is the normally open auxiliary contact of the high-voltage circuit breaker ; RL is the photoresistor, installed in the operating handle of the isolation switch;
H is the indicator light, with the words "Illegal operation, strictly prohibited" written on its outer cover, installed on the door cabinet .
- Delayed gradual lighting with protection function
- DCD-1240 multifunctional rechargeable lighting
- Laser detection and indicating device system circuit design
- Corridor automatic light-off device
- Simple electronic doorbell circuit
- Motor speed photoelectric control circuit
- One of the circuits that control one light in multiple placesb
- Electronic music dimming desk lamp circuit
- Application circuit of CAT3606
- Chandelier brightness controller circuit using thyristor
- stuttering correction circuit
- Rural fish farming control circuit
- Farmland irrigation automatic control circuit a
- DC ammeter
- Proportional frequency discriminator circuit
- Frequency modulator composed of NE566
- collector amplitude modulation circuit
- Double gate field effect transistor high frequency amplifier circuit
- OTL low frequency power amplifier circuit
- Sawtooth wave generator circuit (1)
