Capacitive proximity switch circuit
Source: InternetPublisher:黄土马家 Keywords: Switch circuit proximity switch capacitive BSP Updated: 2021/11/07
It can be used for lighting control, and can also be used in various
places such as anti-theft, alarm, limit, and positioning.
When the human body is close to the metal plate M, the capacitance of Co increases,
the oscillation frequency of the self-excited multivibrator composed of the 555 time base integrated circuit Ai, etc. decreases, and the output pin 6 of the comparator composed of the operational amplifier A2, etc. is low. level, the transistor
VT is turned on, the relay KA is closed, and its contacts control the lighting or alarm system circuit, lighting the lighting or sending out an alarm
signal.
Adjusting the potentiometers RPi and RPz can change the sensitivity of the device, which can be determined according to actual needs.
In situations where the environment is poor and there is a lot of dust, photoelectric control switches are not suitable, and inductive non-contact switches can be used.
- Build a Bluetooth-controlled wireless scoreboard
- Driving circuit for driving light-emitting diodes by IR53HD420
- Motor speed photoelectric control circuit
- AC and DC dual-purpose flash light
- Mains undervoltage and overvoltage protection circuit 2
- Microwave Doppler warning circuit
- Chandelier brightness controller circuit using thyristor
- Gas and smoke alarm circuits with intermittent alarms
- Electronic rapid starter for fluorescent lamps
- Incandescent lamp dimming circuit using thyristor part 4a
- Homemade disinfectant circuit
- High-efficiency speaker circuit for rural stage
- Farmland drainage automatic control circuit
- Farmland irrigation automatic control circuit a
- Proportional frequency discriminator circuit
- Diode square rate detection circuit
- Audio function generator composed of ICL8038
- Parallel crystal oscillator
- Voltage controlled power supply second-order high-pass filter circuit
- Sawtooth wave generator circuit (1)
