Mains undervoltage and voltage loss protection circuit
Source: InternetPublisher:宋元浩 Keywords: Protection circuit BSP monostable circuit Updated: 2020/02/25
It can be used for refrigerator
protection. It uses 7815 three-terminal fixed integrated voltage regulator
Ai and 555 time base integrated circuit Az ( monostable circuit for
delay control).
When the mains power is lower than 180V, the relay KA is released, cutting off the load power supply, and the light-emitting diode VL lights up at the same time. When
the power supply is restored after a power outage, the protection circuit will take 3-5 minutes (set by the potentiometer RP) to make KA close.
- Measurement and analysis of automatic emergency lighting circuit
- IRS2530D electronic ballast circuit diagram
- Blinking LED circuit diagram based on LDR and resistor
- A light fence circuit diagram with LDR
- Infrared remote control device circuit
- "OR" logic element configuration circuit
- SC3071 touch step dimming light circuit
- AC and DC dual-purpose flash light
- Application circuit of CAT3606
- Touch lighting switch circuit three
- Voice controlled flash LED light circuit diagram
- Analysis of rectifier circuit types and principles
- Inpatient pager circuit
- Rural vegetable greenhouse lighting circuit
- Diode Balanced Mixer Circuit
- Junction field effect transistor mixer circuit
- base amplitude modulation circuit
- Parallel crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- color discrimination circuit
