Color changing light emitting diode monitoring thyristor circuit
Source: InternetPublisher:李商隐身 Keywords: LED thyristor BSP Updated: 2021/02/23
In order to monitor the trigger conduction status of two anti-parallel thyristors or bidirectional thyristors, a
monitoring circuit as shown in Figure 13-16 can be used , and the indicator light uses a color-changing light-emitting diode .
If the voltage output through the thyristor V is a symmetrical voltage in the positive and negative half cycles,
the red and green tube cores of the three-color light-emitting tube alternately conduct in the positive and negative half cycles, emitting
orange light. If V outputs only a positive or negative half-cycle voltage,
only one die can pass current and emit red (or green) light. Therefore , the conduction status of the thyristor
can be judged based on the color of the light .
- LED acceleration and deceleration motion display composed of CD4017
- "OR" logic element configuration circuit
- Lighting sound-activated switch circuit using thyristors Part 3
- Colorimeter circuit
- WT8089 holiday lights ASIC
- Three-way music lantern circuit
- Fluorescent lamp electronic ballast circuit 11
- Seven-way flashing light string circuit
- Shock resistant soft start constant current LED lighting circuit
- Incandescent lamp dimming circuit using thyristor part 4a
- stuttering correction circuit
- High-efficiency speaker circuit for rural stage
- Varactor Diode Frequency Modulator
- Diode balanced amplitude modulation circuit
- Crabo oscillator circuit
- Capacitive feedback oscillator circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Three primary color display circuit
- Guest arrival signal recognition circuit
- Sawtooth wave generator circuit (2)
