Seven-way flashing light string circuit
Source: InternetPublisher:D先生 Keywords: flashing light BSP Updated: 2021/12/19
It is a practical L-channel flashing light string controller, and its flashing mode can be programmed in one step. The core device of the circuit is the CS71D17 L-channel
programmed flash integrated U-circuit
produced by Wuxi Aixinke Micro IU subsidiary (htipj'www.wxasic.com). It is packaged in IP -16 standard, making it The iu voltage range is 3~6V and the functions of each pin
are shown in Table 83. CS71 017 circuit has 6 basic flash functions built-in, through
different connection methods of 3 pattern control terminals (131-B3). nJ can be grouped to create a variety of loop patterns. Table 8.4 gives the control termination methods of 14 different patterns
Picture towel. 220V alternating current is passed
through C step-down, VD1, VD2
rectification, vs voltage stabilization and G filtering
, and the output is about 6, _ DC power is pushed
to the integrated block Sichuan Electric Power.
The ②~⑤ and ⑦~⑨ pins of CS71017
directly trigger the bidirectional thyristors
VTHl - VTH7 to drive
the colored lights F, J~E7 to flash and light up
. Since H1 and B2, namely the
⑩ and ⑩ pins, are connected to the high level V. ,. , and Ij3 is the ① pin floating in the air, so the flashing mode of the lanterns E and E7 is
the automatic conversion mode of patterns 1 to 6 (see the 8th mode in Table 8 4). Readers can also change it according to Table 8 4
He flashes pattern. Increasing or decreasing the capacity of (1. in the circuit can change the flashing frequency of the circuit. Usually c. can
be adjusted within the range of iOOf)-")iOOpF. In addition, the power consumption control terminals ⑩ pin Ⅵ and ⑥ pin v(. both Connecting high ILl to flat
V... is a high power consumption output, and the output current is large to meet the requirements of driving the thyristor. If Vu is -1., Vt -1,
it is a low power consumption connection, the output current is small, and it is mainly used for battery power supply. Adapt to the requirements for driving light-emitting tubes and flickering
(1. It is required to use CBB-400V type polyethylene capacitors. VTHl - VTH7 should use small plastic-cut dual-J thyristors such as MAC94A4 type with
smaller . E1_-F: 7 Commercially available colorful light strings can be used, and the light strings can
be arranged in a certain order in the space to form various flashing patterns. There are no special requirements for other components.
- Measurement and analysis of automatic emergency lighting circuit
- IR2153 emergency fluorescent lamp circuit diagram
- Solar battery and charging circuit
- battery charging circuit
- "OR" logic element configuration circuit
- Desk lamp dimming soft switch circuit
- Seven-way flashing light string circuit
- Electronic rapid starter for fluorescent lamps
- Fluorescent lamp dimming circuit composed of thyristors
- Bedside lamp controller circuit
- stuttering correction circuit
- High-efficiency speaker circuit for rural stage
- Simple AGC circuit in transistor radio
- Diode square rate detection circuit
- Wien bridge oscillator circuit
- Series crystal oscillator
- Parallel crystal oscillator
- Schiller oscillator circuit
- common emitter amplifier circuit
- Color display circuit
