One of the single-junction transistor trigger circuits that is not affected by power grid fluctuations
Source: InternetPublisher:宋元浩 Keywords: Unijunction transistor power grid trigger circuit pulse Updated: 2020/03/21
The two circuits introduced below can convert the trapezoidal wave synchronization voltage into a rectangular pulse with a small intermittent period . Its working principle is
to chop the DC voltage by the periodic operation of a zero-volt switch synchronized to the grid frequency. Due to the use of a low-threshold voltage comparator
, fluctuations in the grid voltage have minimal impact on the intermittent width of the synchronization pulse. Therefore, the phase shift angle
is greatly reduced from the influence of grid voltage fluctuations, and the phase shift range is also expanded.
The circuit is shown in Figure 16-10. It uses 555 time base integrated circuit Ai as a single-limit inverting voltage comparator; it uses 7812 three
-terminal fixed integrated voltage regulator A2 to provide stable operating power. Adjusting the potentiometer RP can change the phase shift angle of the output pulse ground e.
- Design and selection of electric control valve system drive
- How to choose the right level of integration to meet motor design requirements?
- Design of an autonomous plant watering system using ATtiny85
- Build a glove-controlled robotic arm
- Tutorial for building a remote-controlled Arduino Air-Boat
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of voice control circuit
- Simple disconnection burglar alarm
- Homemade disinfectant circuit
- Pyroelectric automatic door control circuit
- Multi-channel patrol detection control circuit c
- Multi-channel patrol detection control circuit b
- Thermistor constant temperature control circuit 2b
- Unidirectional thyristor dimming light circuit triggered by unijunction transistor (2)
- Single junction transistor time relay circuit
- Circuit diagram of separately excited switching stabilized power supply using single-junction transistor as pulse generator
- Single junction transistor sine wave oscillator circuit
- Single-junction transistor metronome circuit diagram operating with AC grid
