Fruit and vegetable greenhouse humidity control circuit
Source: InternetPublisher:3228 Keywords: Control circuit BSP AI humidifier Updated: 2020/03/06
This humidity control circuit is suitable for rough humidity
control in spaces with relatively stable humidity and large volume. It consists of power circuit, humidity measurement circuit and humidity control circuit.
Humidity measurement circuit: A self-excited multivibrator is composed of transistors VT7 and VT8. The output signal passes through
an AC-DC converter composed of a rectifier bridge VC4, etc., and then the DC microammeter PA (scale changed to humidity) displays the reading.
Humidity control circuit : It consists of operational amplifier A, Schmidt circuit (VT9, VTio), inverter VTl1, relays
KAi, KAz, electric humidifier EH and fan M, etc.
When the humidity is lower than the set value, relays KAi and KA2 are closed one after another, and the electric humidifier EH and fan M work.
When the humidity rises to the set value, KAi and KA2 are released, and both EH and M stop working.
Adjust the potentiometer RPz to change the humidity set value; adjust RP4 to adjust the trigger sensitivity of the Schmidt circuit.
- Model rocket launch controller circuit
- Controlling LEDs with Node-RED in Raspberry Pi
- How to build a simple tachometer using an infrared reflectance sensor
- An automated model railroad layout project using a microcontroller
- A small improvement to the temperature and water level indicator alarm
- Temperature control circuit design and analysis
- PIC microcontroller controlled remote anti-theft alarm circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Infrared detection alarm
- "Watchdog" anti-theft alarm circuit
- Excellent performance household inverter power supply circuit
- Bone hyperplasia treatment circuit
- Peanut and melon seeds roasting machine circuit
- Rural vegetable greenhouse lighting circuit
- Farmland irrigation automatic control circuit b
- Parallel crystal oscillator
- Voltage series negative feedback amplifier circuit
- Delay integrator circuit
- Wiring using broken wire fluorescent lamps a
- Tone selector modified from tone circuit
