High-precision non-contact temperature control circuit 5
Source: InternetPublisher:清宁时光 Keywords: No contact high precision temperature control circuit BSP Updated: 2021/12/06
This circuit uses the LM3911 temperature detection control integrated circuit.
Integrated circuit A is internally composed of a reference voltage regulator, a temperature sensor and an operational amplifier. The internal reference voltage is 6.85V.
The voltage between its power supply terminal V+ and the output terminal OUT is proportional to the thermodynamic temperature, and the temperature sensitivity rate is +lOmV/ ℃. Because it
has an internal reference voltage regulator, you only need to use a large enough current limiting resistor to keep its operating current within a few milliamps. Its internal
integrated operational amplifier can be used as a comparator. Therefore, it is very convenient to use it as a temperature detection and control device.
According to the component parameters shown in the figure, the adjustment temperature range of the potentiometer RP is 20~60℃.
- Design and selection of electric control valve system drive
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- How to set up a cheap beam break sensor control distance scene using a reflector
- Add one more component to improve the phase failure protection function
- Design and production of radio remote control fan stepless speed regulator
- Audio interface protection circuit
- Electric vehicle battery charging protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Bicycle anti-theft alarm
- Simple disconnection burglar alarm
- Excellent performance household inverter power supply circuit
- High-efficiency speaker circuit for rural stage
- Poultry warming temperature control circuit
- DC ammeter
- Diode square rate detection circuit
- collector amplitude modulation circuit
- ring amplitude modulation circuit
- Differential Amplifier Circuit
- common emitter amplifier circuit
- Color display circuit
