One of the bimetal thermostatic control circuits
Source: InternetPublisher:jikai233 Keywords: Thermostatic control circuit BSP Updated: 2020/11/21
Using the bimetallic sheet of the fluorescent lamp starter,
a temperature sensing element can be made for constant temperature control. Using bimetallic
sheet as the temperature sensing element , the circuit is simple and easy to manufacture, but the temperature control accuracy is poor.
The circuit is shown in Figure 11-39. When making the temperature sensor (bimetallic sheet)
, remove the glass shell of the neon bulb in the starter, leaving
the U-shaped bimetallic sheet fixed on the glass ball and a metal rod.
In order to control the temperature more accurately, the upper end of the metal rod should be
filed and bent, and the distance between the tip and the bimetal piece should be carefully adjusted
so that at the set temperature, the U-shaped bimetal piece is exactly in contact with the tip
of the metal rod
When adjusting
, the temperature inside the thermostat should be observed . Generally, it needs to be adjusted several times.
- Analysis of the working principle of car garage door lights
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Perform surgery on the speaker protection circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Using P110C to control 6 DC motors simultaneously
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and production of no-load automatic power-off device for household power supply
- Guanghua brand anti-theft doorbell electronic lock circuit
- Homemade short circuit alarm device
- Homemade anti-theft watchdog
- stuttering correction circuit
- Ultrasonic blind pathfinder circuit
- Agricultural temperature control circuit
- Agricultural spraying and insecticide control circuit
- Poultry warming temperature control circuit
- Biogas concentration detection line
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Diode Balanced Mixer Circuit
- Frequency modulator composed of NE566
- Home appliance repair signal generator circuit
