KL-25 type thyristor automatic excitation device circuit
Source: InternetPublisher:jikai233 Keywords: excitation thyristor device circuit generator Updated: 2020/05/01
The circuit is shown in Figure 7-32. This excitation device is suitable for
automatically adjusting the excitation of synchronous generators with a terminal voltage of 400V and a capacity of less than 75kW .
In the figure, SB is the starting button. When the generator is pulled to the rated speed by the prime mover, pressing SB for a short time will cause the generator
to self-excite and build up the voltage; RPi is the manual voltage regulating potentiometer, and RPi decreases ( or increase), the generator voltage decreases (or increases
). Adjust RP2 to adjust the sensitivity of the device. If oscillation occurs in the excitation , try lowering the sensitivity.
When shutting down, the switch SA is cut off, and the trigger circuit loses power, and the generator can be demagnetized.
- A small improvement on the ordinary refrigerator motor starting circuit
- A small improvement to the temperature and water level indicator alarm
- Motor automatic cycle control circuit
- Design and production of wireless multi-location control switch circuit
- Design and manufacture of three-phase motor protection circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- An experimental model of an infrared radio alarm
- Delay switch made with LM431
- Night dog barking anti-theft reminder circuit
- Password type motorcycle anti-theft device
- Lightning protection wiring for 300 to 1500kW direct generatorsa
- Four-link semi-continuous casting machine speed regulating circuit
- 7kW diesel engine thyristor voltage regulating circuit
- Added wiring diagram 2 of CJ-12 excitation regulator
- FKL-32 type thyristor automatic excitation device circuit b
- DC electromagnet strong excitation fast pull-in circuit 5
- DC electromagnet strong excitation fast pull-in circuit one a
- A starting circuit that reduces the voltage of the synchronous motor resistance and adds excitation according to the change of the stator current.
- DA converter controls force generator excitation coil circuit
- Strong excitation method of series connected light bulbs
