Delay switch made with LM431
Source: InternetPublisher:小胖友 Keywords: Delay switch LM431 Updated: 2024/11/04
Generally, the delay switch circuit is made of NE555, but its maximum working voltage can only reach 18 volts. Some customers require a delay switch circuit that can work at 24 volts for delayed ignition of cars. I designed a delay switch circuit using LM431, which can work at 24 volts and meet the customer's requirements. The electrical schematic is as follows:
R1 and C1 form a delay circuit. The delay time is required to be 1 second. C1 should be a tantalum capacitor that can work at -55 to +125℃. After power-on, the input of LM431 is low level, the output is about 23 volts, Q1 and Q2 are turned on, the ignition coil is powered for a short time, and the current is about 24 amps. One second after power-on, the input of LM431 rises to 2.5 volts. Since the output of LM431 is about 2. volts at this time, a voltage regulator Z2 with a voltage value of 6.2V should be connected in series at its output, so that Q1 and Q2 can be turned off and the ignition coil loses power. The ignition coil is an inductive load with a DC resistance of about 1 ohm and a 24-volt battery as the working power source. The measured current is about 25 amps. The operating temperature range of this circuit can reach -40 to +121℃, which can fully meet the requirements of automotive electronics.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Design of an autonomous plant watering system using ATtiny85
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Introduction to the internal structure of the Delta winding motor
- Manual automatic air compressor control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Design and production of wireless multi-location control switch circuit
- Design and production of no-load automatic power-off device for household power supply
- PIC microcontroller controlled remote anti-theft alarm circuit
- fire smoke control circuit
- Photocell trigger control circuit
- Digital camera flash control circuit
- Infrared voice control circuit
- AM radio automatic search and trigger circuit
- 8-way electric water heater sequence delay switch control circuit
- Corridor light delay switch circuit 2
- Incandescent lamp voltage delay switch circuit
- Delay switch lighting
- Adjustable relay delay switch
