Asynchronous power generation wiring diagram
Source: InternetPublisher:闪电杰克 Keywords: Asynchronous Wiring Diagram BSP Updated: 2020/10/15
A three-phase cage asynchronous motor is driven by the prime mover (such as a diesel engine, etc.), and
some capacitors are connected in parallel to the outlet end of the stator winding of the asynchronous motor as an excitation power supply, so that three-phase alternating current can be output. This method of power generation is called asynchronous power generation.
The wiring of asynchronous power generation is shown in Figure 7-1. The self-excited capacitor is divided into two parts: one part allows the generator to generate rated voltage
when no-load , which is called the main capacitor (c0);
the other part enables the generator to change from no-load to full load and maintains the rated voltage unchanged, which is called additional capacitance or regulation. Capacitance (lCf, 20).
Capacitors can be metallized film capacitors or self-healing parallel capacitors, such as BCMJ, BFF series, etc., with a rated voltage of not
less than 400V.
The capacitance of the main capacitor can be estimated according to the following formula:
When used for a generator with a rated voltage of 380V,
Cc - 14.5510 (p, F)
When used for a generator with a rated voltage of 220V,
Co = 2510 (and F)
where , Io is the no-load current of the modified asynchronous motor, A.
- Design and selection of electric control valve system drive
- Build a glove-controlled robotic arm
- Motor automatic cycle control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Motor self-starting circuit
- Design and analysis of voice control circuit
- Design and manufacture of three-phase motor protection circuit
- Design and production of no-load automatic power-off device for household power supply
- A novel and practical power line anti-theft and cutting alarm circuit
- Homemade short circuit alarm device
- Self-defense anti-riot circuit
- Smoking Cessation Circuit
- High-efficiency speaker circuit for rural stage
- Fish pond oxygenation reminder circuit
- Peanut and melon seeds roasting machine circuit
- Farmland drainage automatic control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Capacitive feedback oscillator circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Motorcycle flash light circuit
