Use low operating voltage relays for mains circuits d
Source: InternetPublisher:偷熊计划 Keywords: relay Updated: 2020/05/28
If a low operating voltage DC relay is used in commercial power, it needs to be reduced by a step-down transformer and then rectified before it can be used, but
this is costly. For this purpose, a resistor or capacitor step-down circuit can be used , as shown in Figure 6 4.
Figure 6-4 (a) shows the resistor R step-down circuit, the diode VD half-wave rectification, and the capacitor C filter and voltage stabilizing circuit; Figure 6-4 (b)
shows the resistor R step-down circuit, diode bridge rectifier vc, and capacitor C filter and voltage stabilization circuit. circuit. The voltage applied to
the relay KA coil by this circuit is more stable than Figure 6-4 (a). The disadvantage of Figure 6-4 (a) and Figure 6-4 (b) is that the power consumed in the resistor R is large.
Figure 6-4 (d) shows the best performance among the four circuits .
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Tutorial on making your own remote-controlled robotic arm
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Manual automatic air compressor control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Motor self-starting circuit
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and production of radio remote control fan stepless speed regulator
- Ultra-short wave item left behind reminder alarm
- Night dog barking anti-theft reminder circuit
- 13 examples of electric drag control circuit diagram
- Differential amplifier emitter negative feedback gain control circuit
- Boiler control circuit
- Infrared voice control circuit
- Assembly line outage monitoring circuit
- Three-phase stepper motor control circuit
- PLC chain alarm control circuit used in production process
- Typical operation display circuit
- Intelligent iron control circuit
- Micro DC motor steady speed control circuit a
