One of multiple sets of high-power colored light chain circuits that flash in turn a
Source: InternetPublisher:张小哥 Keywords: High power colorful lights Updated: 2020/07/08
Due to the use of relay control (if several pairs of contacts are connected in parallel, the capacity will be larger),
the power of the bulb can be very large, and the circuit is very simple. As long as the capacitance of the capacitor is changed , different flash frequencies can be obtained.
- TEC laser diode driver circuit
- USB powered portable light
- IRS2530D electronic ballast circuit diagram
- Design and production of a practical electronic counting device
- Use NE555 to make a lighting and sound changing circuit
- Electronic massage and acupuncture device circuit
- Power outage emergency lighting
- SC3071 touch step dimming light circuit
- Touch lighting switch circuit three
- Simple sensor alarm
- Using TL431 as a high-power adjustable voltage stabilized power supply
- Eight-function multi-pattern lantern chain circuit using SE9201
- One of the three-function lantern chain circuit using SZ-9201
- High-power lantern chain circuit with adjustable luminous frequency for each group b
- Multiple groups of high-power colored light chain circuits that flash in turn (Part 2)
- Multiple sets of colorful light chain circuits that flash in cycles (Part 3)
- TEA-1000 power amplification improvement example 02
- Practical high-power switching regulated power supply circuit schematic diagram
- Simple fade-in and fade-out switch circuit (2)
- Simple high-power temperature control circuit
