Inverter circuit four
Source: InternetPublisher:闪电杰克 Keywords: Inverter circuit BSP multivibrator Updated: 2020/08/07
It is a separately excited transistor inverter circuit , which can
be used for 8~40W fluorescent lamps. A self- excited multivibrator is composed of transistors VTi, VTz and capacitors Cl, c2, etc. , which
provides excitation current for transistors VT3 and VT4. This circuit can overcome the shortcomings of the circuit in Figure 2-121. The frequency and signal amplitude can be adjusted
by changing the R and C parameters of the multivibrator . According to the component parameters shown in Figure 2-122, it can be used for 8W fluorescent lamps.
The voltage divider composed of resistors Rs, Ra, R7, and R8 controls the input signal amplitude i of VTa and VT4. Ra and R8
can also improve the stability of the output tube and avoid a vicious cycle in which the tube penetration current increases sharply when the temperature rises. .
- Circuit diagram of game score display using 7-segment LED
- Delayed gradual lighting with protection function
- LED Signage with RS232 Port Operation Guide
- Laser detection and indicating device system circuit design
- Musical doorbell without buttons
- Practical sensitive light-controlled switch circuit diagram
- Desk lamp dimming soft switch circuit
- Mains undervoltage and overvoltage protection circuit 2
- Three-way music lantern circuit
- Simple sensor alarm
- electromagnetic field sensor
- Smoking Cessation Circuit
- Agricultural temperature control circuit
- Egg heating control circuit
- Farmland irrigation automatic control circuit a
- AC voltmeter
- Double detuned loop frequency discriminator circuit
- Differential Amplifier Circuit
- Voltage series negative feedback amplifier circuit
- Small current generator circuit
