Lighting sound and light switch circuit 2
Source: InternetPublisher:念慈菴 Keywords: Switch circuit light control switch BSP Updated: 2021/01/30
It is an SGK-I type sound and light control switch circuit . The working principle of this circuit is basically the same as Figure 2-111. The circuit forms
are different as follows.
① Added light-emitting diode VL for power indication and working status indication. When the light is off, VL is on; when the light
is on, VL is off because the thyristor V is conducting.
② The light control sensitivity is adjusted with the voltage dividing resistor Rr; capacitor C3 is connected in parallel to both ends of the photoresistor RG to improve
the anti-interference performance of the light control switch.
③ Add diode VD to improve the reliability of system operation.
- LED acceleration and deceleration motion display composed of CD4017
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- Six LED stereo VU display circuit built with IC LM3915
- Design and production of a practical electronic counting device
- Use NE555 to make a lighting and sound changing circuit
- battery charging circuit
- Practical sensitive light-controlled switch circuit diagram
- "OR" logic element configuration circuit
- Resistor value selection circuit
- Mains undervoltage and overvoltage protection circuit 2
- electromagnetic field sensor
- Self-defense anti-riot circuit
- Bone hyperplasia treatment circuit
- Homemade disinfectant circuit
- Straw returning to field crusher circuit
- Greenhouse temperature control circuit
- Junction field effect transistor mixer circuit
- ring amplitude modulation circuit
- Series crystal oscillator
- Voltage-controlled voltage source second-order active low-pass filter circuit
