Light control switch circuit controlled by flashlight 2
Source: InternetPublisher:走马观花 Keywords: Switch circuit flashlight light control switch Updated: 2021/09/12
It uses 555 time base integrated circuit A and uses a bidirectional thyristor V as a non-contact switch,
so the circuit is simple, has good anti-interference performance and is stable in operation. Photosensitive transistors VTi and VTz are used as detection components.
In Figure 2-103, the resistor Ri plays the role of anti-interference and improving circuit stability.
When the flashlight shines on the phototransistor VTz, the triac V is turned on and the load is turned on; when the flashlight shines on
the VTi, V is turned off and the load is cut off.
- Making a photometer with light measuring function
- A white light LED power outage emergency light
- Fire safety evacuation emergency signs
- Circuit diagram of game score display using 7-segment LED
- LED Flasher circuit using 2 transistors for LED switching
- Low illumination amplifier circuit
- Use NE555 to make a touch self-extinguishing table lamp
- Power outage emergency lighting
- One of the bead-type emergency light circuits
- Colorimeter circuit
- Infrared proximity switch circuit diagram
- Mos tube switch circuit diagram
- FM modulator strong-weak signal switching circuit b
- Touch bistable switch circuit
- Photoelectric control switching circuit composed of photoresistor lamp elements
- Lighting sound and light control switch circuit 4
- One of the light control switch circuits controlled by flashlight
- Light control switch circuit 3 controlled by flashlight
- Simple light control switch circuit
