Street light control circuit four
Source: InternetPublisher:宋元浩 Keywords: Light control circuit BSP Updated: 2020/05/31
The circuit is simple and uses a capacitor to step
down and then stabilize the voltage to provide working power for the trigger circuit. When it is dark, the resistance of
the photoresistor RG is very large, the transistor VT is turned
on, the triac V is triggered and turned on, the relay KA is closed, and the street
light is lit. Adjusting the resistance of resistor Ri can change the action brightness setting value
(ie, the sensitivity of the device).
- One-digit display
- Fire safety evacuation emergency signs
- USB powered portable light
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Musical doorbell without buttons
- battery charging circuit
- Low illumination amplifier circuit
- Infrared remote control dimmer light circuit
- Motor speed photoelectric control circuit
- Touch lighting switch circuit three
- stuttering correction circuit
- Greenhouse temperature control circuit
- Soil water shortage prompt circuit
- Junction field effect transistor mixer circuit
- Varactor Diode Frequency Modulator
- base amplitude modulation circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage series negative feedback amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- color discrimination circuit
