Fluorescent lamp dimming circuit three
Source: InternetPublisher:三月小雨 Keywords: Fluorescent lamp dimming circuit BSP Updated: 2021/02/28
(3) Fluorescent lamp dimming circuit three
The circuit is shown in Figure 2-80. This dimmer can dim the 40W fluorescent lamp within the range of 10-40W.
The phase-shift trigger circuit is composed of a single-junction transistor VT, a resistor Rz, a potentiometer RP and a capacitor C1. By adjusting RP,
the conduction angle of the thyristor Vl can be changed, which also changes the conduction angle of the bidirectional thyristor V2, thereby realizing the adjustment of fluorescent lamps. Light.
In Figure 2-80, the ballast L is the ballast with the original fluorescent tube; the core of the transformer T is made of ordinary silicon steel sheet with a cross-section
of 19mm×19mm, and the primary is wound with 2860 turns of enameled wire with a diameter of 0.15mm ; the winding of 25V Use
enameled wire with a diameter of O.lmm to wind 660 turns; the 6.3V winding uses a diameter of o. 59mm enameled wire wound with 83 turns.
- Experiment on realizing photoelectric alarm using photosensitive devices
- TEC laser diode driver circuit
- IRS2530D electronic ballast circuit diagram
- Blinking LED circuit diagram based on LDR and resistor
- Use NE555 to make a lighting and sound changing circuit
- Musical doorbell without buttons
- Microwave Doppler warning circuit
- Digital display multi-function thermometer circuit
- Remote anti-theft alarm
- Fluorescent lamp electronic ballast circuit 11
- strain sensor
- Analysis of rectifier circuit types and principles
- Pulse therapy circuit
- Crop anti-frost circuit
- Soil water shortage prompt circuit
- Audio function generator composed of ICL8038
- Wien bridge oscillator circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Various signal generator circuits
- Sawtooth wave generator circuit (1)
