Serial debugger circuit implemented with several discrete components
Source: InternetPublisher:子丑寅卯 Keywords: Serial communication RS-232 serial port Updated: 2023/11/27
The typical RS-232 serial port signal swings between positive and negative levels. When sending data, the sending end driver outputs positive levels between +5V and +15V, and negative levels between -5V and -15V. However, the microcontroller serial port Generally it is TTL level (0V~5V). Two serial ports cannot simply be connected directly with wires.
It uses VD2 and C1 to obtain the negative power required for communication from the RS-232 interface, and can well achieve level conversion and data communication between the two interfaces. The author's years of use have proven that the communication effect is very good, and, in When the operating voltage is 3.3V, it is still very stable.
If the circuit in the picture is made into a small circuit board, it can be installed into an RS-232 socket, and VCC, TXD, RXD, and GND can be connected with four-core cables to create a universal serial data communication line.
- How to generate time delay using 8051 timer?
- How to connect ADC to 8051 microcontroller?
- Working principle of DCC module, practical application and precautions of DCC module
- How to Interface PCF8591 ADC Module with Raspberry Pi
- Make an Interactive Arcade Bedside Clock
- Interface circuit composed of photocoupler
- Sample and hold amplifier AD9101 interface circuit
- How to Implement a Bipolar LED Driver Circuit Using 8051 Microcontroller
- Interface circuit between 51 single chip microcomputer and MAX7219
- Use PC’s RS232 port to control LED lights
