Interface circuit composed of photocoupler
Source: InternetPublisher:ohahaha Keywords: Coupler Interface Circuit Updated: 2024/08/29
As shown in the circuit, the photocoupler 4N25 plays the role of coupling pulse signals and isolating the single-chip computer 89C51 system and the output part, making the two parts of the current independent of each other. The ground wire of the output part is connected to the chassis or the earth, while the power ground wire of the 89C51 system is floating and not connected to the ground wire of the AC power supply. This can avoid the impact of the output part power supply change on the single-chip computer power supply, reduce the interference to the system, and improve the system reliability.
- Make an alcohol tester based on 8051 microcontroller
- Are more bits in an MCU better?
- Application circuit of CSJ-R05B and single chip microcomputer
- Using 89C2051 to make a four-way digital display water level controller circuit
- Circuit design analysis of smart car image recognition system
- Experiment on using 51 microcontroller to drive relay
- Cable test circuit
- p4 478 chip pin distribution diagram
- USB to parallel port, serial port circuit diagram (ch341)
- Minimum system circuit of XC4003
- Minimum system interface circuit based on AT89C52 microcontroller
- Using 8255 to expand 64-channel input interface circuit
- DAC0832 single-bipolar voltage output interface circuit
- AD574 and RS-232C interface circuit
- Touchpad interface circuit (IBM ThinkPad T60)
- Interface circuit for automatic counting using electronic counter b
- Interface circuit between CMOS and PMOSb
- Interface circuit between thyristor and TWH7851 switch integrated circuit
- Interface circuit between power supply coupler and transistor a
- Industrial control circuit and CMOS interface circuit
