Incandescent lamp dimming circuit using thyristor Part 6
Source: InternetPublisher:同住地球村 Keywords: Thyristor incandescent lamp dimming circuit BSP Updated: 2021/01/18
(6) The sixth incandescent lamp dimming circuit using thyristor
The circuit is shown in Figure 2-71. It uses a trigger circuit composed of bidirectional thyristors and single-junction transistors, and has good dimming effect.
The pulse transformer TM can use a ferrite core, and both the primary and secondary are wound with 60 to 80 turns of enameled wire with a diameter
of 0.2mm; it can also use a 6mm×8mm E-shaped silicon steel sheet core, and both the primary and secondary use a diameter of 0.2mm. Each enameled wire is wound with
300 turns.
- A white light LED power outage emergency light
- USB powered portable light
- IRS2530D electronic ballast circuit diagram
- LED Flasher circuit using 2 transistors for LED switching
- battery charging circuit
- One of the water full alarm circuits
- SC3071 touch step dimming light circuit
- Corridor automatic light-off device
- Gas flameout alarm circuit
- Gift lamp music box circuit
- Agricultural temperature control circuit
- High-efficiency speaker circuit for rural stage
- Crop anti-frost circuit
- Straw returning to field crusher circuit
- Agricultural spraying and insecticide control circuit
- Farmland drainage automatic control circuit
- Diode Balanced Mixer Circuit
- Varactor Diode Frequency Modulator
- collector amplitude modulation circuit
- Wien bridge oscillator circuit
