TL431 battery charger
Source: InternetPublisher:偷熊计划 Keywords: TL431 charging circuit Updated: 2023/11/27
Charging a battery beyond the specified battery voltage will significantly reduce its life expectancy.
Here we introduce a simple charging circuit, which uses a three-terminal adjustable shunt voltage regulator chip TL431 (IC1) as the main regulating device. When the voltage of the non-inverting input pin (REF) is lower than its internal reference voltage (2.5V), the TL431 cathode K outputs a high potential, keeping the relay in the release state and charging continues. on the contrary. When the battery voltage exceeds the threshold voltage of the circuit. When the REF voltage exceeds 2.5V. TL431 cathode K outputs low potential. The relay is closed, the charging circuit is disconnected, and charging stops. TL431 plus several external components form a charging control circuit. Because TL431 provides a reference voltage internally. Therefore, the TL431 comparator has a hysteresis effect, that is, there is a difference between the upper and lower limits of the comparator.
The threshold voltage of the circuit is the upper limit of the charging voltage. This upper limit voltage can be calculated according to the following formula: VT=Vref×(1+R1/R2), where Vref is the internal reference voltage of TL431, which is approximately 2.5V.
When the battery voltage rises to exceed the threshold voltage, relay RL1 is closed, its contact N/C disconnects the charging circuit, and the indicator LED1 flashes. At the same time, R3 provides a hysteresis path to control the release voltage Vr of the relay. Vr can be calculated by the following formula: Vr=Vref×(1+R1||R3/R2). In the formula, R1||R3 is the parallel value of R1 and R3, that is, (R1xR3)/(R1+R3).
When the battery voltage is lower than the release voltage, the cathode (K) voltage of TL431 is close to the battery voltage. The relay remains in the released state. Charging continues and LED1 does not flash. Until the recharged battery voltage exceeds the threshold voltage Vt, LED1 flashes again and charging stops. R5 is used to limit the charging current.
The power supply of the charger is provided by the 220V AC power supply through the step-down transformer X1 and the D1~D4 rectifier bridge.
The circuit can be mounted on an ordinary PCB board and enclosed in an appropriate box. Use alligator clips to connect the battery when charging.
- 12v high power battery charging circuit diagram
- What effect does the copper coating on the bottom of the inductor have on the power supply?
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Benefits of Wide Bandgap Technology for Power Converters
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Recommended circuits for different power on times of LM4911
- LED rechargeable flashlight circuit diagram
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Adjustable regulated power supply with current limiting protection
- Two smartphone charging circuit diagrams
- Battery constant current charging circuit
- Half-wave rectifier, divided-block adjustable charging circuit
- General circuit diagram of a simple battery automatic constant current charging circuit
- RC charging circuit
- Automatic battery charging circuit 02
- Voltage peak incremental automatic charging circuit
- TL431 AC voltage regulator circuit diagram
- Lithium battery constant current and constant voltage charging circuit diagram
- TL431 circuit diagram
