Simple Battery Charger Circuit
Source: InternetPublisher:张七岁 Keywords: Charger circuit Updated: 2024/07/30
This charger is simple to make, works stably and reliably, and has a wide adjustment range. It does not require high-power and high-current thyristors, and can charge any 6V:24V battery. R6 and C4 make the load approximately resistive. R1: 100K, R2: 1K, R3: 3K, R4: 470K (variable), R5: 360 ohms, R6: 360 ohms, C1: 0.1uf/160V, C2: 0.1uf/160V, C3: 0.01uf/600V, C4: 0.01uf/600V, ST: trigger bidirectional diode, bidirectional thyristor: 10A/600V, transformer: about 100W 220V/30V, rectifier bridge: 15A/100V, ammeter: 10A, voltmeter: 50V.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- ISO113 circuit that can reduce power consumption
- LED Driver ZD1680
- Adjustable regulated power supply with current limiting protection
- LM317 regulated power supply
- Adjustable voltage regulated power supply circuit
- The production of adjustable voltage-stabilized power supply composed of LM317
- Homemade home inverter circuit diagram
- Nickel cadmium battery charger circuit 2
- Automatic charger circuit
- Motorcycle battery charger circuit
- Electric bicycle battery fast charger circuit
- Charger circuit that can restore the vitality of over-discharged batteries
- Multipurpose battery charger circuit
- Battery charger circuit (1)
- PUT battery charger circuit
- Universal battery charger circuit (2)
- Constant voltage current limiting charger circuit
