High-voltage pulse generator
Source: InternetPublisher:smallembedded Keywords: High voltage generator Updated: 2024/07/08
As shown in the figure, the circuit can generate a high voltage pulse using a 6V~12V DC power supply. The transistors VTl and VT2 in the circuit form an oscillator, which generates a DC pulse voltage with a frequency of 3Hz and outputs a primary coil of a 6V:240V booster with a transformation ratio. At the end of each pulse, a high voltage is generated in the secondary coil of the transformer accordingly. The repetition frequency of the pulse can be adjusted by selecting the values of C2 and Rl. When this circuit is used in a baton, a lead-acid battery can be used.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Fabrication of multi-cell lithium battery charging circuit
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Use pulse width modulation to get a precise output voltage
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Dual forward converter schematic diagram
- A small and easy-to-make fast charger
- CNC regulated power supply production
- Adjustable voltage power socket
- Car Audio Power Supply
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- Power supply circuit with multiple outputs (MAX1902)
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- Karaoke light controller circuit (1)
- Remote control TV doorbell power circuit
- Music power circuit
- Power circuit for home appliance repair
- Neon light high voltage power supply circuit
- Inverter power circuit made with BJ50A
- Always ready power circuit
