PCB circuit board heat dissipation method
Source: InternetPublisher:公子李 Keywords: PCB Updated: 2021/09/28
There are more and more circuits nowadays, but one key issue is very important, and that is heat dissipation. For electronic equipment, a certain amount of heat will be generated when working, which will cause the internal temperature of the equipment to rise rapidly. If the heat is not dissipated in time, , the equipment will continue to heat up, the device will fail due to overheating, and the reliability of the electronic equipment will decrease. Therefore, it is very important to handle the heat dissipation of the circuit board well. The heat dissipation of PCB circuit board is a very important link. So what are the heat dissipation techniques of PCB circuit board? Let’s discuss it together.
There are techniques for PCB circuit board heat dissipation, which can be designed like this:
1. Heat dissipation through the PCB board itself. The currently widely used PCB boards are copper-clad/epoxy glass cloth base materials or phenolic resin glass cloth base materials, and there are also a small amount of paper-based copper-clad sheets. Although these substrates have excellent electrical properties and processing properties, they have poor heat dissipation. As a heat dissipation path for high-heating components, it is almost impossible to expect the PCB resin itself to conduct heat, but to dissipate heat from the surface of the component to the surrounding air. However, as electronic products have entered the era of component miniaturization, high-density installation, and high-heat assembly, it is not enough to rely solely on the surface of components with very small surface areas to dissipate heat. At the same time, due to the extensive use of surface-mounted components such as QFP and BGA, the heat generated by the components is transferred to the PCB board in large quantities. Therefore, the best way to solve the problem of heat dissipation is to improve the heat dissipation capacity of the PCB itself that is in direct contact with the heating components, through the PCB board Conduct or radiate out.
2. Add radiators and heat conduction plates to high-heating devices. When there are a few devices in the PCB that generate a large amount of heat (less than 3), you can add a radiator or heat pipe to the heating device. When the temperature still cannot drop, A radiator with a fan can be used to enhance the cooling effect. When there are a large number of heating devices (more than 3), a large heat dissipation cover (board) can be used. It is a special radiator customized according to the position and height of the heating device on the PCB board or a large flat-panel radiator. Cut out the high and low positions of different components. Attach the entire heat dissipation cover to the component surface and make contact with each component to dissipate heat. However, due to the poor consistency of the components during assembly and soldering, the heat dissipation effect is not good. Usually, a soft thermal phase change thermal pad is added to the component surface to improve the heat dissipation effect.
3. For equipment that uses free convection air cooling, it is best to arrange the integrated circuits (or other devices) vertically or horizontally.
4. Use reasonable wiring design to achieve heat dissipation. Since the resin in the board has poor thermal conductivity, and copper foil lines and holes are good conductors of heat, increasing the remaining rate of copper foil and adding thermal holes are the main means of heat dissipation. To evaluate the heat dissipation capability of PCB, it is necessary to calculate the equivalent thermal conductivity (nine eq) of the insulating substrate for PCB, which is a composite material composed of various materials with different thermal conductivity.
5. Devices on the same printed board should be arranged according to their heat generation and heat dissipation degree as much as possible. Devices with small heat generation or poor heat resistance (such as small signal transistors, small-scale integrated circuits, electrolytic capacitors, etc.) should be placed In the uppermost part of the cooling airflow (at the entrance), devices with high calorific value or good heat resistance (such as power transistors, large-scale integrated circuits, etc.) are placed at the most downstream part of the cooling airflow.
6. In the horizontal direction, high-power devices should be arranged as close to the edge of the printed board as possible to shorten the heat transfer path; in the vertical direction, high-power devices should be arranged as close to the top of the printed board as possible to reduce the temperature impact of these devices on other devices when they are working. Impact.
7. The heat dissipation of the printed boards in the equipment mainly relies on air flow, so the air flow path must be studied during design and the devices or printed circuit boards should be reasonably configured. When air flows, it always tends to flow in places with low resistance, so when configuring devices on a printed circuit board, avoid leaving a large air space in a certain area. The same issue should also be paid attention to in the configuration of multiple printed circuit boards in the whole machine.
8. Devices that are sensitive to temperature are best placed in the area with the lowest temperature (such as the bottom of the device). Never place it directly above the heating device. It is best to arrange multiple devices staggered on the horizontal plane.
9. Arrange the devices with the highest power consumption and heat generation near the best heat dissipation location. Do not place high-heat components in the corners and edges of the printed board unless a heat sink is arranged nearby. When designing the power resistor, choose a larger device as much as possible, and make sure there is enough space for heat dissipation when adjusting the printed board layout.
10. Avoid the concentration of hot spots on the PCB, distribute the power evenly on the PCB as much as possible, and keep the PCB surface temperature performance uniform and consistent. It is often difficult to achieve strict uniform distribution during the design process, but areas with too high power density must be avoided to avoid hot spots that may affect the normal operation of the entire circuit. If possible, it is necessary to conduct thermal efficiency analysis of printed circuits. For example, the thermal efficiency index analysis software module added to some professional PCB design software can help designers optimize circuit design. The above are some techniques and methods for heat dissipation, which require engineers to continuously accumulate in practice.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Basic connection circuit of signal and power supply composed of ISOll3
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LNK304 non-isolated LED light string driver circuit
- Charging control circuit made by solar energy
- Design of electric vehicle charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- The production of adjustable voltage-stabilized power supply composed of LM317
- MAX1811 Lithium Battery Charger Production
- Switching power supply circuit composition and detailed explanation of each part (1)
- Design of adjustable DC stabilized power supply circuit module
- Industrial product promotion and shopping guide DC power supply circuit
- Typical Reference Voltage and Power Supply Circuits
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- Timing switch AC power circuit
- led drive power circuit
- Industrial four-way programmable controller power circuit
- Household emergency power circuit
- Common power circuits and applications 08
