LM2596 voltage regulator
Source: InternetPublisher:武林萌主 Keywords: Regulated power supply LM2596 Updated: 2024/07/08
When designing the entire control system, if the power supply system is too complex and redundant, it will not only cause electromagnetic interference to other circuits, but also have poor economic benefits. Therefore, all chips in the design are selected with 5 V, 3.3 V or 1.8 V power supply voltage. In this way, when designing the power supply, only three LM2596s and some capacitors, inductors, diodes, etc. are needed to directly convert the 24 V voltage into the required voltage. The circuit design is not only easy but also very economical. The power supply circuit is shown in Figure 6. When using it specifically, you can choose LM2596-5V, LM2596-3.3V, LM2596-1.8V chips as needed. To obtain +1.8 V and +5 V, use the connection method of Figure 6 (a), and to obtain +3.3 V, use the connection method of Figure 6 (b).
- Basic circuit description of adjustable voltage regulator LM317
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Driving circuit that controls LED brightness using PWM signal
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- Homemade low-power UPS
- Car power 1.5V-12V six-speed converter
- 0.7~24V continuously adjustable current limiting power supply
- Mc34063 MP3 Switching Charger
- Practical constant current charger-----Constant current charger
- Switching power supply circuit composition and detailed explanation of each part (1)
- Power circuit of STR5412
- One of the transistor stabilized current power supply circuits
- Class A power amplifier power circuit
- led drive power circuit
- Household emergency power circuit
- Common power circuits and applications 09
- Common power circuits and applications 01
- 25Hz ring current power supply circuit
- Small power UPS power circuit and production
