High voltage series switching power supply
Source: InternetPublisher:公子李 Keywords: Switching Power Supply Updated: 2024/07/11
After the article "CATV Series Switching Power Supply" was published in the 24th issue of "Electronic News" last year, a reader called and said that he hoped to provide a series switching power supply with input AC220V and output DC200V0.2A. After designing the experiment, the author obtained the circuit shown in the attached figure, whose output voltage is quite stable and the efficiency is over 85%. The working principle of this circuit is the same as above, so I will not repeat it here.
Component selection: IRF740 (400V 10A) for VT1, C2299 (400V 0.5A) or MPSA42 (300V 0.5A) for VT2, P2298T (400V 0.5A) or MPSA94 (300V 0.5A) for VT3. The inductance of inductor L can be between 100~200μH. If you want to make it yourself, you can use Φ0.31mm wire to wind 30 turns on the EI28 ferrite core, and there should be a gap in the core. The power of R not marked in the figure is 1/4W, and VT1 must add a heat sink. When the output voltage is 200V, it is replaced by a fixed resistor according to the actual data after RP adjustment. When the output voltage of this circuit is adjusted to 150V, the load current can reach 1A, and the output voltage is quite stable. If used in other occasions, the wire diameter of inductor L should be thickened, and the rest does not need to be changed.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Benefits of Wide Bandgap Technology for Power Converters
- Visible laser digital control modulation driver
- Transformerless AC-DC constant current LED driver circuit
- LED rechargeable flashlight circuit diagram
- Switching power supply circuit composition and function introduction of each part
- Low cost and high performance LED constant current power supply
- MIC4680 constant current charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- MAX1811 Lithium Battery Charger Production
- How should the power supply be decoupled?
- The most detailed explanation of ATX power supply, please find out!
- Inspection methods for various components in power supplies
- Layout and design principles of switching power supply
- DC switching power supply schematic diagram
- Small power switching power supply circuit diagram
- DVD switching power supply circuit schematic diagram
- Switching power supply drive circuit
- High-fidelity power amplifier using switching power supply 02
- Three-terminal PWM switching power supply-PWR-TOP200 series and applications 03
