High-precision voltage regulator using KTA431 (TL431)
Source: InternetPublisher:武林萌主 Keywords: TL431 voltage regulator Updated: 2024/07/10
The attached figure is a circuit diagram of a high-precision voltage regulator using a shunt regulator IC. Since negative feedback is introduced into the circuit, a stable output voltage can be obtained.
The output voltage is determined by the ratio of the voltage divider resistors R6 and R7. Vout = Vref × (R6 + R7) / R6, so the output voltage can be set to any value by simply adjusting the ratio of the voltage divider resistors.
Since the regulator uses a PNP transistor as the adjustment tube, the base potential is lower than the input voltage, so the voltage difference between the input and output of the regulator may be lower than the Vce (sat) of the transistor. When the input voltage changes greatly, or even when it is close to the set voltage value, the circuit can still work normally. In order to prevent the parallel voltage regulator IC from causing self-excitation of the circuit, phase compensation measures must be taken in the circuit. Therefore, an RC series circuit is connected between the cathode and base (Ref) of KIA431A. For the series-adjusted regulator, the voltage difference between the input and output is added to the adjustment tube. The product of the voltage difference and the load current is the loss of the transistor. When designing the circuit, be sure not to let the maximum power loss of the transistor exceed the rated power of the transistor, and pay attention to adding a heat sink for heat dissipation.
- Benefits of Wide Bandgap Technology for Power Converters
- Basic circuit description of adjustable voltage regulator LM317
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED rechargeable flashlight circuit diagram
- Switching power supply circuit composition and function introduction of each part
- Boost drive circuit composed of RT8450
- An ultra-low output voltage regulator
- Power supply circuit that can reduce LM317 ripple
- MIC4680 constant current charger
- Power supply circuit design optimized for digital light projectors
- Laser power circuit
- Industrial product promotion and shopping guide DC power supply circuit
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Low voltage adjustable reference power circuit
- Household emergency power circuit
- TL431 forms a series voltage regulator circuit
- Overvoltage protection circuit diagram using TL431 precision reference source, etc.
- Basic application circuit diagram of TL431 b Adjustable quasi-source circuit diagram
