Production of adjustable regulated power supply composed of TL431
Source: InternetPublisher:同住地球村 Keywords: TL431 regulated power supply circuit Updated: 2023/12/05
The picture shows a regulated power supply circuit that uses TL431 as the voltage reference and an external field effect transistor K790 as the adjustment tube to form a continuously adjustable 2.5V ~ 30v, and the output current can reach 6A.
Working principle: As shown in the figure, the 220v voltage is stepped down by transformer B, rectified by D1~D4, and filtered by C1. In addition, D5, D6, C2, and C3 form a voltage doubler circuit (making Vdc=60V), RW and R3 form a voltage divider circuit, TL431 and R1 form a sampling amplifier circuit, 9013 and R2 form a current limiting protection circuit, and FET K790 is used for adjustment. tube (can be used directly in parallel) and C5 is the output filter circuit, etc. The voltage stabilization process is: when the output voltage decreases, the potential of point f decreases. The internal amplification of TL431 increases the voltage at point e. After adjustment by K790. The potential of point b increases; conversely, when the output voltage increases, the potential of point f increases and the potential of point e decreases. After adjustment by K790, the potential of point b decreases, thereby stabilizing the output voltage. When the output current is greater than 6A, the transistor 9013 is turned off, limiting the output current to within 6A, thereby achieving the purpose of current limiting.
The resistor R1 of this circuit is 2w, and the resistor R2 is 5w.
- Methods for Suppressing Conducted Radiation in the FM Band
- In-depth analysis of DC-AC converter inverter
- Fabrication of multi-cell lithium battery charging circuit
- Practical and convenient fax machine power supply control circuit
- Detailed explanation of 5v charger circuit diagram
- LNK304 non-isolated LED light string driver circuit
- Voltage-current converter constructed with XTR110
- Adjustable voltage power socket
- MIC4680 constant current charger
- Adjustable voltage regulated power supply circuit
- STR5412 power circuit
- Excellent performance household inverter power supply circuit
- Portable device charging power circuit design
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- KGDS type single-phase low temperature iron plated power supply circuit
- CF1 (CF2) DC power supply circuit
- Recording level power supply circuit
- Basic application circuit diagram of TL431a Reference source circuit diagram
- TL431 programmable precision voltage reference circuit diagram
