Fluorescent lamp circuit adapted to low voltage and low temperature Part 2a
Source: InternetPublisher:三岁就很酷 Keywords: Fluorescent lamp Updated: 2020/05/29
(2) Circuit 2 adapted to fluorescent lamps with low voltage and low temperature
. The circuit is shown in Figure 2-9. Figure 2-9 (a) shows
a button (or pull switch) connected in parallel to the starter , which is called the short-circuit starting method; Figure 2-9 (b) shows
a diode and button connected in parallel to the starter, called a diode Activation method. When these
two circuits are in use, press the button SB (1~2s) and then release it to
quickly start lighting the fluorescent lamp .
- One-digit display
- Use NE555 to make a touch self-extinguishing table lamp
- Power outage emergency lighting
- One of the bead-type emergency light circuits
- Motor speed photoelectric control circuit
- Chandelier brightness controller circuit using thyristor
- Electronic rapid starter for fluorescent lamps
- Incandescent lamp dimming circuit using thyristor part 4a
- Fluorescent dimming circuit (1)
- Bedside lamp controller circuit
- Direct current ignites fluorescent lamp circuit
- Fluorescent lamp DC starting circuit
- Fluorescent lamp dimming circuit three
- Fluorescent lamp electronic ballast circuit 14
- Fluorescent lamp electronic ballast circuit 12
- Fluorescent lamp electronic ballast circuit 2
- U-shaped fluorescent lamp wiring b
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- Centralized starting device for fluorescent lighting controlled by AC contactor
- Hitachi double tube emergency fluorescent lamp circuit diagram
