Wiring of high pressure mercury lamp and high pressure sodium lampb
Source: InternetPublisher:张三叔 Keywords: Wiring high pressure sodium lamp reflective BSP Updated: 2021/11/12
High-pressure mercury lamps, also known as high-pressure mercury lamps, are available in three types: external ballast, self-ballasted
and reflective . The reflective high-pressure mercury lamp is only coated with an aluminum reflective layer on the upper inner wall of the glass bulb
, and does not require a lampshade when used. Self-ballasted high-pressure mercury lamps do not require a ballast. The wiring of the high-pressure mercury lamp
is shown in Figure 2-5 (a). The wiring of the high-pressure sodium lamp is shown in Figure 2-5 (b).
- Audio level LED and digital dual display circuit
- Six LED stereo VU display circuit built with IC LM3915
- LED Flasher circuit using 2 transistors for LED switching
- Laser detection and indicating device system circuit design
- Design and production of digital number answering machine
- Lighting lamp voltage stabilizing circuit (2)
- Power outage emergency lighting
- Photoelectric adjustment circuit
- Reverse polarity drive circuit
- Night target display circuit diagram
- Motor forward and reverse control wiring diagram (2)
- Set timing circuit when power is on
- Physiotherapy ventilator circuit
- Agricultural temperature control circuit
- Farmland irrigation automatic control circuit a
- Diode Balanced Mixer Circuit
- collector amplitude modulation circuit
- Crabo oscillator circuit
- Capacitive feedback oscillator circuit
- Small current generator circuit
