TDA1521 two-channel power amplifier OTL connection and OCL connection
Source: InternetPublisher:念慈菴 Keywords: Power amplifier circuit Updated: 2023/12/07
Philips' TDA1521 two-channel audio power amplifier integrated circuit has a good reputation among audiophiles due to its good sound quality and easy production. TDA1521 adopts a nine-pin single-in-line plastic package, with high output power, small gain difference between the two channels, and overheating, overload and short circuit protection.
In actual circuit applications, the internal resistance of the power supply powering TDA1521 should be less than 4 ohms to ensure that its load short-circuit protection circuit can operate reliably. TDA1521 must be equipped with a heat sink plate not less than 200mm×100mm×2mm. During the debugging process, do not try to connect the output terminal of the TDA1521 to the input terminal, otherwise the integrated block will burn out quickly.
TDA1521 characteristic parameters: (Vcc=±16V RL=8Ω f=1KHz Ta=25℃)
2. Output power: Po =2×12W (THD=0.5%) Po = 30 W in BTL form
3. Voltage gain: Gv = 30dB
4. Channel isolation: CT=70dB 5. Output noise voltage: Vno = 70uV (Rg=2KΩ)
TDA1521 can work under either single power supply or dual current, so there are two different circuit connections, OTL and OCL. The following is the specific circuit form:
TDA1521 single power supply OTL connection method
![TDA1521 two-channel power amplifier OTL connection method and OCL connection method TDA1521 AMPLIFIER](http://www.eeworld.com.cn/circuit/upload/202301/4/194fb01ba793dae29f5eba588e16ead3e2d5157c.gif)
- Homemade high quality preamplifier tone circuit
- Field effect tube amplifier circuit with beautiful sound
- Make a high-quality DAC board
- 75W audio power amplifier made with TMOS150
- 6BX7 10W bile duct amplifier
- Amplifier circuit made by parallel connection of FU-50
- Volume synchronization circuit constructed with discrete components
- Auxiliary audio power amplifier circuit using LM4732
- 2W×2 power amplifier circuit using LM1877
- Typical circuit of LM4809/LM4810 for dual-channel headphone amplifier
- 175MHz high frequency power amplifier circuit composed of field effect transistors
- 50Wx2 high-fidelity power amplifier circuit
- Application circuit of LM3886
- 50W super class A power amplifier circuit
- Gentleman AM50 amplifier circuit
- High quality audio amplifier circuit
- Veuve Clicquot 4B7 radio OTL power amplifier circuit
- Making LM1875 DC negative feedback BTL power amplifier circuit
- High-quality power amplifier circuit of LF356+TDA1514
- Current pouring power amplifier circuit
