TDA7265 dual-channel audio power amplifier integrated circuit
Source: InternetPublisher:清宁时光 Keywords: TDA7265 power amplifier circuit diagram Updated: 2024/07/03
TDA7265 is a dual-channel audio power amplifier integrated circuit produced by STMicroelectronics (ST), suitable for high-end TVs and Hi-Fi playback equipment, with mute and standby functions. The chip integrates two audio power amplifier circuits with the same functions and over-current protection, overheat protection, short-circuit protection circuits, and some other auxiliary function circuits.
TDA7265 working power supply: ±6V~±25V, output power: 25+25W (total harmonic distortion = 10%, RL = 8Ω, power supply = ±20V)
TDA7265 appearance: TDA7265 pin function:
1. Negative power supply 2. Output 1 3. Positive 4. Output 2 5. Mute control 6. Negative power supply 7. Positive input 2 8. Negative input 2 9. Bottom line 10. Negative input 1 11. Positive input 1
TDA7265 typical application circuit (positive and negative dual power supply, OCL circuit):
TDA7265 bridge application circuit diagram (BTL circuit):
TDA7265 single power supply application circuit diagram (OTL circuit):
- lm3886 circuit diagram explanation, lm3886 schematic diagram
- Tutorial on making a MIDI arpeggio synthesizer
- Make a high-quality DAC board
- Toy electronic chicken
- Amplifier circuit made by parallel connection of FU-50
- Typical applications of optocouplers in audio amplifier circuits
- Minimum output noise/reduced output power circuit using LM4910
- 8W audio power amplifier circuit composed of LM2002/LM2002A
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- American Grado RA1 headphone amplifier
- Digital power amplifier circuit diagram using 555
- TDA2009 single power amplifier circuit diagram
- TDA4601 power amplifier circuit diagram
- AN7161N power amplifier circuit diagram
- AN7147 power amplifier circuit diagram
- AN7117 power amplifier circuit diagram
- TDA1515B power amplifier circuit diagram
- TDA1521 power amplifier circuit diagram
- TDA2007 power amplifier circuit diagram
- TDA2008 power amplifier circuit diagram
