Three working states of transistor - PNP type - saturation state
Source: InternetPublisher:fish001 Keywords: Transistor BSP collector Updated: 2021/05/14
Cut-off state:
When "≤0", the collector current is very
small, the transistor is equivalent to cut-off, and the power supply
voltage mound is almost entirely applied to both ends of the tube.
Amplification state:
"Gradually increasing from O, the collector current
J also increases according to a certain proportion. A small
change in I causes a large change. The transistor
plays an amplifying role.
Saturation state:
When the three-input tube is saturated, the voltage drop across the tube is very
small, and almost all of the power supply voltage E is applied to the collector
load. The larger the I port at both ends of the collector load resistor, the more
sensitive the control.
- One-digit display
- LED Signage with RS232 Port Operation Guide
- Practical sensitive light-controlled switch circuit diagram
- SC3071 touch step dimming light circuit
- Motor speed photoelectric control circuit
- Simple light-controlled street light circuit (7)
- Gas and smoke alarm circuits with intermittent alarms
- Two-way electronic music doorbell circuit
- Fluorescent lamp electronic ballast circuit 11
- Four color light circuit
- High-efficiency speaker circuit for rural stage
- Rural fish farming control circuit
- Straw returning to field crusher circuit
- Poultry warming temperature control circuit
- AC voltmeter
- Junction field effect transistor mixer circuit
- Audio function generator composed of ICL8038
- Second-order active band-stop filter circuit
- Wireless microphone circuit
- Fault signal trip circuit
