Three working states of the transistor - NPN type - saturation state
Source: InternetPublisher:fish001 Keywords: Transistor BSP collector Updated: 2021/02/07
Cut-off state:
When "≤0", the collector current is very
small, the transistor is equivalent to cut-off, and the power supply
voltage mound is almost entirely applied to both ends of the tube.
Amplification state:
"Gradually increasing from O, the collector current
J also increases according to a certain proportion. A small
change in I causes a large change. The transistor
plays an amplifying role.
Saturation state:
When the three-input tube is saturated, the voltage drop across the tube is very
small, and almost all of the power supply voltage E is applied to the collector
load. The larger the I port at both ends of the collector load resistor, the more
sensitive the control.
- One-digit display
- TEC laser diode driver circuit
- Six LED stereo VU display circuit built with IC LM3915
- Infrared remote control device circuit
- "OR" logic element configuration circuit
- Transistor storage time test circuit
- AC and DC dual-purpose flash light
- Telephone theft automatic notification device circuit diagram
- Shock resistant soft start constant current LED lighting circuit
- Simple sensor alarm
- High-efficiency speaker circuit for rural stage
- Rural fish farming control circuit
- Straw returning to field crusher circuit
- Poultry warming temperature control circuit
- AC voltmeter
- Junction field effect transistor mixer circuit
- Audio function generator composed of ICL8038
- Second-order active band-stop filter circuit
- Wireless microphone circuit
- Fault signal trip circuit
