SL-322 integrated circuit multi-function protection circuit b
Source: InternetPublisher:公子李 Keywords: Protection circuit integrated circuit BSP motor Updated: 2021/12/09
This circuit uses SL-322 integrated circuit . Its output end has several light-emitting diodes and a sensitive relay. According to the number of light emitting diodes, the operating current of the motor
can be read to monitor the operation of the motor
. If overcurrent occurs, the sensitive relay will act to realize the shutdown function. In the figure, the potentiometer RP is the output value given potentiometer
. By adjusting it, the output current value can be set to any given value in the range of 5 to 50A; to meet the requirements of automatic shutdown.
The circuit also has a phase failure protection function.
When the motor is overloaded, the voltage U. rises, pin 6 of SL-322 outputs high potential, the sensitive relay KA closes, the contactor
KM releases, and the motor stops. At the same time, the bell HA and the indicator light H send out an alarm signal.
Thermal relay FR serves as overload backup protection and phase failure protection.
- How to choose the right level of integration to meet motor design requirements?
- Build a glove-controlled robotic arm
- Tutorial for building a remote-controlled Arduino Air-Boat
- DIY an electromagnetic levitation device
- A small improvement on the ordinary refrigerator motor starting circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- PIC microcontroller controlled remote anti-theft alarm circuit
- Infrared blocking alarm device
- Ultra-short wave item left behind reminder alarm
- Infrared detection alarm
- Bone hyperplasia treatment circuit
- Agricultural temperature control circuit
- Egg warming circuit
- Soil water shortage prompt circuit
- base amplitude modulation circuit
- collector amplitude modulation circuit
- OTL low frequency power amplifier circuit
- Differential Amplifier Circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Sine wave signal generator circuit
